ir_fuel 58.276 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 Is hier nog geen topic van? Moet zowat de zotste auto zijn die ooit gemaakt is. Voor @gTa en andere geïnteresseerden, echt de moeite om helemaal uit te kijken. Spast Schmee heeft er ook een video over maar die heb ik na 2 minuten opgegeven, holy moly wat een debiel. Koenigsegg is producing only 125 units of the Jesko, with a choice between the so-called top speed version that achieves the headline-grabbing 300 mph and a more track-oriented variant, the latter of which is on show in Geneva this week. Despite a mind-melting $2.8 million starting price before tax, 90 of the cars had already been pre-sold before the Jesko’s official unveiling, and Koenigsegg’s been doing brisk business during the show, with expectations that the company will leave Switzerland with all its Jesko orders filled. Built around a redesigned 5-liter twin-turbo V8 engine, the Koenigsegg Jesko can hit 1,280 horsepower with regular gasoline or 1,600 horsepower on E85 biofuel. It has the world’s lightest crankshaft (weighing 12.5 kilograms / 27.5 pounds), which is milled from a single billet of steel and helps the engine work more efficiently. There’s also an acoustic benefit to the new crankshaft design, which Koenigsegg says helps to produce an “even more visceral engine sound.” A new nine-speed Light Speed Transmission system has been designed in-house, promising ”gear changes [that] occur in virtually zero time between adjacent gears.” It’s accompanied by an Ultimate Power On Demand predictive gear-changing technology that will ensure “instant, prolific power that’s always optimised and always available, allowing maximum acceleration for overtaking, corner exits, etc.” Bron: https://www.theverge.com/2019/3/7/18254447/koenigsegg-jesko-megacar-specs-top-speed-photos-geneva-motor-show-2019 8 1 Quote
Lotuzzz 17.062 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 Best ook even passeren bij de familie van Hooydonk https://www.jesco.be 1/3 1 Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 Ik heb even een fout in je post aangepast. Geen dank. 2 Quote
Timo 16.072 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 Wat zou die vleugel kosten, 40-50k of nog een pak meer (x2)? Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 3 minutes ago, Timo said: Wat zou die vleugel kosten, 40-50k of nog een pak meer (x2)? Kom je niet mee toe. Quote
JanC 7.872 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 Absurd, vooral die versnellingsbak, je vraagt je af waarom niemand anders daar eerder op kwam. Ik denk dat het antwoord met kosten te maken heeft... Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 58 minutes ago, JanC said: Ik denk dat het antwoord met kosten te maken heeft... Of "nutteloos" Hoeveel auto's moeten 1500Nm koppel kwijt geraken? Ik denk dat de meerwaarde van zo een bak tov een DSG nihil is in een auto van 600pk. Quote
Soundstorm 2.632 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 2 hours ago, Timo said: Wat zou die vleugel kosten, 40-50k of nog een pak meer (x2)? Als je puur naar kostprijs kijkt, dan is dat een week werk en een combinatie van relatief goedkope materialen. Dus volgens mij heb je dat wel voor minder dan 20k gemaakt. Als je alles gaat meerekenen van ontwikkeling (deel die kost door het aantal vleugels dat je gaat maken) en dan nog de nodige winst, zit je volgens mij los over de 100k. 1 hour ago, JanC said: Absurd, vooral die versnellingsbak, je vraagt je af waarom niemand anders daar eerder op kwam. Ik denk dat het antwoord met kosten te maken heeft... Slijtage waarschijnlijk. Die ketels zijn niet gemaakt om 300000km mee te rijden. Het wordt ook geaccepteerd dat je daar elk jaar een maand mee in de garage staat en 50k achter laat voor het onderhoud. Geen schakeltijd kan je met veel systemen doen, maar het zorgt altijd voor veel slijtage en stress. Misschien dat zij wel iets gevonden hebben waar het wat soepeler mee gaat. Het gebruik van 9 versnellingen helpt wel al. Quote
Soundstorm 2.632 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 29 minutes ago, ir_fuel said: Of "nutteloos" Hoeveel auto's moeten 1500Nm koppel kwijt geraken? Ik denk dat de meerwaarde van zo een bak tov een DSG nihil is in een auto van 600pk. Feit is wel dat als het zo'n kleine lichte bak kan zijn, dat het ook interessant is voor de normale productiewagens. Als je dat wat kan verschalen, heb je een enorm kleine versnellingsbak voor je 1.0 Polo, terwijl die nu toch nog een 25-30kg weegt. Of je maakt 1 versnellingsbak voor je hele productlijn, die het maximum koppel van je sterkste motor aan kan. Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 32 minutes ago, Soundstorm said: Slijtage waarschijnlijk. Die ketels zijn niet gemaakt om 300000km mee te rijden. Het wordt ook geaccepteerd dat je daar elk jaar een maand mee in de garage staat en 50k achter laat voor het onderhoud. Waarom zou dat harder slijten? 32 minutes ago, Soundstorm said: Geen schakeltijd kan je met veel systemen doen, Volgens mij kunnen bestaande systemen dat enkel tussen opeenvolgende versnellingen. Quote
Glenn-N 8.593 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 6 uren geleden, ir_fuel zei: Mind = blown. WTF. Quote
vince522 2.493 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 Presentatie van het salon zelf is ook de moeite om te zien, daar gaat Christiaen dieper in op het mechanisme om de deuren te openen. De deur gaat nu hoger open zodat het risico van de stoep te raken beperkt wordt en het is zo ontwikkeld dat ze dit kunnen retrofitten op hun andere modellen, hoe zalig is dat niet. 1 Quote
Timo 16.072 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 5 hours ago, ir_fuel said: Kom je niet mee toe. Dus die voorste lip/spliter kapot rijden gaat je ook een 150-200k kosten. Quote
Soundstorm 2.632 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 6 hours ago, ir_fuel said: Waarom zou dat harder slijten? Volgens mij kunnen bestaande systemen dat enkel tussen opeenvolgende versnellingen. Die schakeltijden verkorten doen ze meestal door 2 versnellingen ter gelijker tijd te selecteren en koppelingen te laten slippen. Geen idee hoe ze het hier precies doen, maar korte schakeltijden geven sowieso meer slijtage, de 'kloppen' zijn veel groter. Kan dit systeem even snel schakelen bij het overslaan van versnellingen? Volgens zijn uitleg is het toch ook een algoritme dat inschat wat de volgende versnelling zal moeten zijn. Dat kan even goed slechts eentje op/neer zijn. Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 9 minutes ago, Soundstorm said: Kan dit systeem even snel schakelen bij het overslaan van versnellingen? Ja. Heb je de video niet bekeken? Quote
ir_fuel 58.276 Geplaatst: 8 maart 2019 Auteur Geplaatst: 8 maart 2019 11 minutes ago, Soundstorm said: maar korte schakeltijden geven sowieso meer slijtage, de 'kloppen' zijn veel groter. Maar de tijd die je in "slip" doorbrengt is dan weer korter. Quote
Soundstorm 2.632 Geplaatst: 8 maart 2019 Geplaatst: 8 maart 2019 2 minutes ago, ir_fuel said: Ja. Heb je de video niet bekeken? Kan me niet herinneren dat hij dat specifiek zei. 1 minute ago, ir_fuel said: Maar de tijd die je in "slip" doorbrengt is dan weer korter. Korter, maar heviger. Netto dus evenveel kans op slijtage. Quote
ir_fuel 58.276 Geplaatst: 9 maart 2019 Auteur Geplaatst: 9 maart 2019 1 hour ago, Soundstorm said: Korter, maar heviger. Netto dus evenveel kans op slijtage. Dat lijkt me toch niet helemaal te kloppen. Dat is zoals zeggen dat je remmen op circuit niet harder afzien wanneer je lang maar zacht remt tov kort en hard. Quote
Krikkie 9.828 Geplaatst: 9 maart 2019 Geplaatst: 9 maart 2019 Zullen eerder de lagers, tandwielen en dergelijke zijn die er last van hebben. Quote
JanC 7.872 Geplaatst: 9 maart 2019 Geplaatst: 9 maart 2019 Goed voor een whiplash, dat systeem, toch in dit ding. Quote
tuscani 11.787 Geplaatst: 15 juni 2025 Geplaatst: 15 juni 2025 https://www.instagram.com/p/DK6ievcoop8/?img_index=1&igsh=N24yNnRxZXFlb2Fv Vorige week een filmpje gezien , waar hij zijn zoontje op school komt ophalen. En nu dit. Quote
