Thebiemerke 5.382 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 It looks like we'll get some limited-edition GP models after all. The evolution of the Mini, at least from a styling standpoint, hasn’t been too dramatic over the years. That could be one of the reasons why this winged wonder was spied by our photographers without any sort of camouflage. We think it’s a high-performance John Cooper Works GP version, which we saw in a concept form a year ago at the Frankfurt Motor Show. There’s another more applicable reason, however, for this test car to be running without coverings. We’re likely seeing a test mule wearing a standard Mini Cooper S body with upgraded bits underneath. If you recall, the JCW GP Concept was rather flamboyant with its body kit, scoops, and of course the big wing on the back. The wing is the obvious giveaway that something different is happening on this Mini – it’s a dead ringer for the concept’s wing, but couldn’t this just be a Cooper S with a spoiler on the roof? The metal strip down low on the front fascia and the red sensor box tell us this is some kind of test mule, and the brake rotors behind the wheels look bigger as well. For that fast, the exhaust tips at the rear appear larger, too. If this is a test mule for a new higher-performance JCW GP variant, what other kinds of performance tweaks can we expect? The larger exhaust points to more power than the current 228 horsepower (170 kilowatts) available in the JCW. How much more isn’t confirmed, but rumors suggest something in the 280 - 300 hp (209 - 224 kW) range. We’ve already seen larger brakes, and there would certainly be some suspension tuning for better poise at the track. Expect some carbon fiber infusion as well to help reduce weight. Mini did a limited run of previous GP models, and now that we’ve seen a car on the street running with the big wing, it seems a new batch of hardcore track-focused models are in development. As for when it will be available, that will likely happen sometime late next year, or early in 2020. Source: CarPix 1 Quote
Stancke 4.650 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 GP was al bevestigd maar goed. Wordt een ontzettend dik spel, wel enkel automaat normaliter én gelimiteerde oplage. En 52k dacht ik Quote
William Blake 2.844 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 Automaat dan toch min. een DCT? Quote
Luv4DLM 1.280 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 Te vroeg gekocht@Niko80 [emoji23]Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote
Gast Dirk75 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 24 minuten geleden, William Blake zei: Automaat dan toch min. een DCT? De beschikbare dct kan het koppel niet aan... de jcw heeft ook,de aisian. Quote
Niko80 6.866 Geplaatst: 4 september 2018 Geplaatst: 4 september 2018 38 minutes ago, Luv4DLM said: Te vroeg gekocht@Niko80 Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Precies, maar niks dat niet kan veranderd worden. @Stancke regelt dat wel. Quote
Luv4DLM 1.280 Geplaatst: 5 september 2018 Geplaatst: 5 september 2018 9 uren geleden, Niko80 zei: Precies, maar niks dat niet kan veranderd worden. @Stancke regelt dat wel. Als je dat koopt mag je me bij de volgende rit een 30min voorsprong geven. Quote
Niko80 6.866 Geplaatst: 5 september 2018 Geplaatst: 5 september 2018 5 hours ago, Luv4DLM said: Als je dat koopt mag je me bij de volgende rit een 30min voorsprong geven. Nu ook al Quote
Luv4DLM 1.280 Geplaatst: 5 september 2018 Geplaatst: 5 september 2018 Nu ook al [emoji6] Niet gemerkt zaterdag [emoji41]Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote
William Blake 2.844 Geplaatst: 5 september 2018 Geplaatst: 5 september 2018 15 uren geleden, Dirk75 zei: De beschikbare dct kan het koppel niet aan... de jcw heeft ook,de aisian. zonde, vreemd geheel dan, een 'racy' GP MINI en dan zo'n zachte automaat met koppelomvormer... steek gewoon een leuke handbak 2 Quote
Alexis 5.938 Geplaatst: 5 september 2018 Geplaatst: 5 september 2018 1 hour ago, William Blake said: zonde, vreemd geheel dan, een 'racy' GP MINI en dan zo'n zachte automaat met koppelomvormer... steek gewoon een leuke handbak Dit Quote
DuDe 1.211 Geplaatst: 6 september 2018 Geplaatst: 6 september 2018 Niet echt fan van die opzichtige strijkplank achteraan.. Quote
Gast Dirk75 Geplaatst: 7 september 2018 Geplaatst: 7 september 2018 (aangepast) Ik denk dat deze de motor van de x2 35i zal krijgen. 306pk 450Nm all4 en sportdifferentieel. Met de 8 traps automaat. 0 tot 100 rond de 5 seconden... 7 september 2018 aangepast door Dirk75 Quote
Stancke 4.650 Geplaatst: 8 september 2018 Geplaatst: 8 september 2018 Ik denk dat deze de motor van de x2 35i zal krijgen. 306pk 450Nm all4 en sportdifferentieel. Met de 8 traps automaat. 0 tot 100 rond de 5 seconden...Krijgt minder PK's, zou rond de 280 zitten en all4 is niet mogelijk op dit chassis. Mechanisch sper zou eronder zitten. 1 Quote
Gast Dirk75 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 (aangepast) Op 5/9/2018 om 13:11, Niko80 zei: Nu ook al Niko, vind jij je automaat traag, zacht,.. ? http://www.motoringfile.com/2017/12/18/mini-dct-dual-clutch-transmission-makes-official-debut/ 9 september 2018 aangepast door Dirk75 Quote
Luv4DLM 1.280 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 Niko, vind jij je automaat traag, zacht,.. ?Ik heb met zijn 2 Mini's gereden, de bak in de JCW is een pak vlotter in schakelen dan de Cooper S. Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote
Gast Dirk75 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 (aangepast) 1 uur terug, Luv4DLM zei: Ik heb met zijn 2 Mini's gereden, de bak in de JCW is een pak vlotter in schakelen dan de Cooper S. Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Kan kloppen, maar zijn s was een 6 traps. De huidige s, heeft de 7 traps dct. De 1.5 met 136pk doet de 0-100 in 7,8 seconden... met 7 traps dct… wel straf... 9 september 2018 aangepast door Dirk75 Quote
Niko80 6.866 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 Niko, vind jij je automaat traag, zacht,.. ?http://www.motoringfile.com/2017/12/18/mini-dct-dual-clutch-transmission-makes-official-debut/ Nee helemaal niet. Staat goed afgesteld.Maar voor echt te spelen zou hij manueel mogen zijn.Verstuurd vanaf mijn FIG-LX1 met Tapatalk Quote
Niko80 6.866 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 Kan kloppen, maar zijn s was een 6 traps. De huidige s, heeft de 7 traps dct. De 1.5 met 136pk doet de 0-100 in 7,8 seconden... met 7 traps dct… wel straf...8 traps de nieuwe.Verstuurd vanaf mijn FIG-LX1 met Tapatalk Quote
Gast Dirk75 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 12 minuten geleden, Niko80 zei: 8 traps de nieuwe. Verstuurd vanaf mijn FIG-LX1 met Tapatalk Uwe jcw heeft nog de klassieke 8 traps met interne updates, wegens teveel aan koppel. Quote
Niko80 6.866 Geplaatst: 9 september 2018 Geplaatst: 9 september 2018 Uwe jcw heeft nog de klassieke 8 traps met interne updates, wegens teveel aan koppel. [emoji6]Geen idee. Is een LCI dus zou moeten de nieuwste zijn. Kan 7traps zijn ook, is een Aisin boite dat weet ik wel. Anders@Stancke to the rescue.Verstuurd vanaf mijn FIG-LX1 met Tapatalk Quote
jvc 543 Geplaatst: 13 februari 2019 Geplaatst: 13 februari 2019 Uitlaat is wel mn ding, die spoiler iets minder Quote
Niko80 6.866 Geplaatst: 15 februari 2019 Geplaatst: 15 februari 2019 Ga er mijn geld niet aanhangen. Na twee Mini's is het wel geweest. Quote
