ir_fuel 58.282 Geplaatst: 14 december 2018 Geplaatst: 14 december 2018 "een leuk interieur in uw auto van 150K? Geen probleem meneer! U hebt de keuze uit ..." In de 100D heb je iets meer mogelijkheden, maar wil je een zwart interieur moet je hout pakken Op dat punt staan ze toch nog mijlenver achter op de concurrentie. Quote
Jokke_vlo 16.911 Geplaatst: 14 december 2018 Geplaatst: 14 december 2018 Dan moet je elders gaan shoppen, is nodig om aan de vraag te voldoen. Dat versta ik nu ergens wel. Vraag > aanbod. Quote
Gixxer 611 Geplaatst: 17 december 2018 Geplaatst: 17 december 2018 (aangepast) https://www.youtube.com/watch?v=Cjib5a587BM 17 december 2018 aangepast door Gixxer Quote
Gast wooter Geplaatst: 17 december 2018 Geplaatst: 17 december 2018 https://www.teslarati.com/elon-musk-tesla-new-easter-egg-fart-app-romance-mode-video/ Quote
Gast wooter Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 https://electrek.co/2018/12/18/tesla-software-update-winter-video-game-mars/ Nieuwe update met nieuwe features: Mobile App When you precondition your car using the mobile app, you can now turn on, off, or adjust any of your seat heaters. If available in your car, you’ll also be able to turn on your steering wheel heater. Note Requires mobile app version 3.8.0 or greater. Keep Climate On You can now keep your car (and its contents) at the temperature of your choice, even after you’ve left. To help ensure that you have enough battery to drive to your next destination, the climate control will automatically turn off if the battery level reaches 20%. You can always monitor your car and adjust the temperature using the Tesla mobile app. You will receive a notification that the battery has reached 20% and that the climate control has turned off. This reminds you to check on anything you’ve left in the car. To see the climate control to stay on, tap the fac icon at the bottom of the touchscreen when your car is parked. Enable keep Climate On and make any adjustments. You can leave knowing that your car will stay comfortably cool or warm. Note: The next time you drive your car, the climate control will reset to the previous settings from your most recent trip. Emissions Testing Mode Prank your friends with Tesla’s Emissions Testing Mode. To setup, tap the Tesla ‘T’ at the top of the center of the touchscreen, then tap the whoopee cushion icon in your Easter Egg tray. Select your desired sound and choose the seat where you want to sound to originate from. When ready, play the whoopee cushion sound by pressing the left scroll wheel button. Romance Mode Experience the warmth of our virtual fireplace with Romance Mode. To enable Romance Mode when your car is in Park, tap the Tesla ‘T’ at the top center of the touchscreen, then tap the fireplace logo in your Easter Egg tray. Pole position Drive a Tesla around Mars in the TeslAtari version of Pole Position. To play when your car is Park, turn your steering wheel to maneuver, press the brake pedal to adjust speed, and use the scroll wheels to shift gears. As with all TeslAtari games, you can play by tapping the Tesla ‘T’ at the top of the center of the touchscreen, then tap the Atari logo in your Easter Egg tray and select your desired game from the drop down menu. Quote
ir_fuel 58.282 Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 Ze houden u wel aangenaam bezig tijdens het superchargen Quote
ir_fuel 58.282 Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 Misschien heb je erover gelezen of heb ik het antwoord niet gezien, maar zijn er nu dingen die een Model S/X wel kunnen die een Model 3 niet kan? En dan heb ik het niet over de automatische koffer of over de deurgrepen, maar genre AP ofzo. Quote
Gast wooter Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 Nee, AP2.x is identiek op Model X, S en 3. Model S heeft automatische klinken en auto lift gate, Model X heeft automatische deuren en auto lift gate, Model 3 heeft enkel manuele klinken en geen auto lift gate. Quote
Gast wooter Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 25 minutes ago, ir_fuel said: Ze houden u wel aangenaam bezig tijdens het superchargen Ik had die Atari spelletjes nog niet eens gespeeld :). Heb ze dan eens gespeeld in de Eurotunnel, zowat de enige keer dat ik in de auto zit terwijl de auto niet rijdt. Quote
Gast wooter Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 Overigens de 2e keer van de 2 keren dat ik de Eurotunnel met een Model X neem, dat ik wordt verwezen naar de explosieventest waarna de beambten hun test doen en vervolgens kletsen over wat zo een Tesla al dan niet kan :). Quote
Gast wooter Geplaatst: 19 december 2018 Geplaatst: 19 december 2018 https://electrek.co/2018/12/18/tesla-model-3-ccs-charging-station/ Quote
Gast wooter Geplaatst: 21 december 2018 Geplaatst: 21 december 2018 https://electrek.co/2018/12/20/tesla-taxi-rides-amsterdam-airport/ Ik mag zo weer met de mijne rijden Quote
Gast wooter Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Visualisatie van wat Tesla AP 2.5 herkent. Quote
Germinal 464 Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 https://electrek.co/2018/12/18/tesla-software-update-winter-video-game-mars/ Nieuwe update met nieuwe features:Mobile App When you precondition your car using the mobile app, you can now turn on, off, or adjust any of your seat heaters. If available in your car, you’ll also be able to turn on your steering wheel heater. Note Requires mobile app version 3.8.0 or greater.Keep Climate On You can now keep your car (and its contents) at the temperature of your choice, even after you’ve left. To help ensure that you have enough battery to drive to your next destination, the climate control will automatically turn off if the battery level reaches 20%. You can always monitor your car and adjust the temperature using the Tesla mobile app. You will receive a notification that the battery has reached 20% and that the climate control has turned off. This reminds you to check on anything you’ve left in the car. To see the climate control to stay on, tap the fac icon at the bottom of the touchscreen when your car is parked. Enable keep Climate On and make any adjustments. You can leave knowing that your car will stay comfortably cool or warm. Note: The next time you drive your car, the climate control will reset to the previous settings from your most recent trip.Emissions Testing Mode Prank your friends with Tesla’s Emissions Testing Mode. To setup, tap the Tesla ‘T’ at the top of the center of the touchscreen, then tap the whoopee cushion icon in your Easter Egg tray. Select your desired sound and choose the seat where you want to sound to originate from. When ready, play the whoopee cushion sound by pressing the left scroll wheel button.Romance Mode Experience the warmth of our virtual fireplace with Romance Mode. To enable Romance Mode when your car is in Park, tap the Tesla ‘T’ at the top center of the touchscreen, then tap the fireplace logo in your Easter Egg tray.Pole position Drive a Tesla around Mars in the TeslAtari version of Pole Position. To play when your car is Park, turn your steering wheel to maneuver, press the brake pedal to adjust speed, and use the scroll wheels to shift gears. As with all TeslAtari games, you can play by tapping the Tesla ‘T’ at the top of the center of the touchscreen, then tap the Atari logo in your Easter Egg tray and select your desired game from the drop down menu.Dat ze is eerst een knop voorzien om uw stuurverwarming uit/aan te zetten zonder allemaal menu’s te moeten doorploeteren en/of uw ventilatie te moeten aanzetten!Kwestie van eerst nutteloze dingen te voorzien zeker?? Quote
Gast wooter Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Sorry ze maar iemand die zelfs de ventilatie uit zet in de auto spoort niet. Heb je dat al aan Tesla zelf laten weten dat je de nieuwe methode niet gewenst vind? Of zit je enkel op dit forum wat te janken? Stuurverwarming zou overigens 2 taps zijn, dus niet allerlei menu's waar je moet doorploeteren. Quote
Germinal 464 Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Sorry ze maar iemand die zelfs de ventilatie uit zet in de auto spoort niet.LOLIk zie ‘t verband echt niet.Met zo’n opmerkingen moet ik@jokke_vlo straks nog gelijk geven [emoji18]Wooter : Ze voorzien onderaan icoontjes om de verwarming van de voor en achterruit aan te zetten.. maar niet voor t stuurwiel? Daar zie ik de logica ook niet van in.Ach misschien is mijn logica en andere dan die van tesla ?Op verschillende fora is er al over gezaagd geweest, maar goed, die mensen zullen ook niet sporen hé. Quote
BMWMB 12.351 Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 De Tesla is zeker niet perfect. Mijn ergernissen zijn de vloermatten die niet blijven liggen, een regensensor die slecht werkt, een voicecontrol die niet in het Nederlands werkt, een zeer slechte menu voor de contactlijst van de telefoon, en zo zijn er nog wel wat dingen. Maar, bij elke auto zijn er zo wel opmerkingen. Perfectie in autoland bestaat niet. Quote
Gast wooter Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Ik vind het erg vreemd om echt de ventilatie uit te zetten in zo een auto. A/C kan ik half nog begrijpen, maar dan moet je ook accepteren dat dat ding niet auto kan werken (omdat je de mogelijkheid van koelen ontneemt) maar echt de ventilatie uitzetten is toch verstikkend? Beslaan dan je ramen niet na 5 minuten? Je superdeluxe biofilter doet dan ook quasi niks, behalve wat er nog zou kunnen binnenkomen via rijwind. Dat die knop van dat stuurwiel achter 2 taps zit vind ik niet zo abnormaal. De voorzetels zitten op het eerste scherm, en je stuurwiel en de achterzetels zitten dus op dat tweede scherm dat volledig voor klimaatcontrole is voorzien. Het duurde voor mij langer om de stuurverwarming in onze M2 terug te vinden hoor. Die knop zit op de stuurkolom, niet zichtbaar voor de bestuurder en passagier, aan de linkerkant. Pas op dit filmpje zie ik dat er ook een LED op hoort te zitten. In een Tesla met V9: Quote
BMWMB 12.351 Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 22 minuten geleden, wooter zei: Sorry ze maar iemand die zelfs de ventilatie uit zet in de auto spoort niet. Heb je dat al aan Tesla zelf laten weten dat je de nieuwe methode niet gewenst vind? Of zit je enkel op dit forum wat te janken? Stuurverwarming zou overigens 2 taps zijn, dus niet allerlei menu's waar je moet doorploeteren. Daar ben ik het volledig mee eens. Mijn airco staat altijd aan, in automatische modus, want dat werkt perfect, waardoor ik nooit met de instellingen moet prullen. Net als alle andere functies in de Tesla, moet je dat idd via het scherm doen. Dat is nu eenmaal het concept van de Tesla, en ik vind dat super. Quote
BMWMB 12.351 Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Op 14/12/2018 om 10:53, ir_fuel zei: "een leuk interieur in uw auto van 150K? Geen probleem meneer! U hebt de keuze uit ..." In de 100D heb je iets meer mogelijkheden, maar wil je een zwart interieur moet je hout pakken Op dat punt staan ze toch nog mijlenver achter op de concurrentie. Ik ben ook eens gaan kijken op de website, en idd, zelfs carbon sierlijsten zijn niet meer te krijgen. Wat ben ik blij dat ik eerder heb besteld, want dat lelijk lichtkleurig hout zou ik niet willen. Quote
Gast wooter Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 Ik hoop dat Tesla snel terug wat meer opties en kleuren in interieur en exterieur gaat voorzien want het is inderdaad een beetje armoede naar keuzes, maar anderzijds kunnen ze nu al niet volgen met productie, dus wat zouden ze missen aan verkopen nu ze die opties niet meer aanbieden? Quote
Gast wooter Geplaatst: 22 december 2018 Geplaatst: 22 december 2018 https://electrek.co/2018/12/21/tesla-mobile-app-update-seat-heating-service-scheduling/ App update: Quote
