Denniske 7.651 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 This is the new Ford Focus ST – the fastest version of the world’s most fun-to-drive family car. It gets a 280hp 2.3-litre petrol engine based on the one fitted to the old Focus RS and comes with a grippy electronically controlled limited-slip differential. Ford Focus price and release date Ford hasn’t revealed the price of the new Ford Focus ST but you can expect it to start from around £26,000 for a basic model with a petrol or diesel engine. Top-of-the-range ST3s will cost closer to £30,000, although that’s still cheaper than a Honda Civic Type R or a Volkswagen Golf R. Ford Focus ST styling The Focus ST gets a number of styling revisions that make it look sportier than a regular Focus. Up front, you get a new grille and a ground-scraping front bumper, while at the back there’s a roof-mounted spoiler and exhausts on the left and right-hand side of the car mean you can now use your Focus ST for towing. You can choose from standard 18-inch or optional 19-inch alloy wheels and colours include Ford Performance Blue (as seen here), Orange Fury, Frozen White, Magnetic grey, Race Red, Ruby Red and Shadow Black. Ford Focus ST interior Inside, the Focus gets a sports steering wheel, Recaro sports seats, aluminium gear shifter, alloy pedals, ‘metallic hexagonal and satin silver decorative elements’ – whatever they are – and metal grey stitching for the seats, door inserts and centre console. 2019 Ford Focus ST engines You can have your Focus ST with either a diesel or petrol power. For performance worthy of the name you’ll want to go for the petrol model that produces 280hp from the engine that was fitted to the old Focus RS. Ford says that’s enough to get the Focus ST from 0-62mph in under six seconds. It’ll comes equipped with a sports exhaust that crackles and pops and also, for the first time, anti-lag. Borrowed from the Ford GT, it cancels out turbo-lag by keeping the turbo spinning even when you don’t have your foot on the accelerator. The diesel Focus does without the anti-lag but still produces 190hp and 400NM of torque – the last figure being the one that’ll make the most noticeable impact – giving the diesel a punchy mid-range that’ll make it feel quick on the motorway. Both the diesel and the petrol get a six-speed manual gearbox as standard with a seven-speed automatic on the options list. 2019 Ford Focus ST driving As well as being faster than a normal Focus, the 2019 Ford Focus ST also handles better in corners. It gets 18-inch alloy wheels, grippy Michelin Sport Pilot tyres, steering that’s quicker even than the slightly flighty Fiesta ST’s – with just two turns lock-to-lock – and suspension that’s lowered by 10mm compared to the regular model’s and is available with adjustable dampers. Of most interest is the inclusion of the electronically controlled limited-slip differential that’ll help the front of the car bite into the tarmac when you accelerate out of corners instead of spinning all it’s power away in a cloud of tyre smoke. More cool kit comes in the form of the Focus ST’s six-speed manual gearbox that has an auto-blip function that matches the car’s engine speed to the new gear for smoother gear changes as you slow down. And the ST has more powerful brakes than the regular car with larger discs and callipers. Ford claims they resist fade almost four times better than the brakes on the old Focus ST. The brakes – along with the steering, throttle pedal, LSD and stability control – can be adjusted using the car’s drive selector. The most aggressive setting is Track mode, which optimises the car for a race circuit – lowering the assistance of the power steering, making the throttle more aggressive and optimizing the limited-slip differential to provide as much traction as possible. Bron: https://www.carwow.co.uk/ford/focus-st/news/3573/ford-focus-st-price-specs-release-date?fbclid=IwAR0XojNhH8mSzwbYIOQqVhgOPDXvYd3C7Wbhm-uGkt-tRj9jDoGzYsWnVag Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 Best dik vind ik! Benieuwd of er ook een mechanische sper als optie komt, elektronische handrem is wel kudt. 1 Quote
Le Capri Mauve 1.012 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Ik denk dat dat interessant gaat worden. Quote resisted fade almost four times better. Hm. De passagiers slapen ook twee keer zo goed en de kwaliteit van het interieur is 40% verbeterd. Quote
ir_fuel 58.442 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 4 minutes ago, Denniske said: Benieuwd of er ook een mechanische sper als optie komt Er zit toch een mechanisch sper op, elektronisch aangestuurd? 1 Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 4 minuten geleden, ir_fuel zei: Er zit toch een mechanisch sper op, elektronisch aangestuurd? Ah, mooi! Quote
Beta 139 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Veelbelovende wagen! Het uiterlijk is wat braaf imo, maar qua rijplezier wordt dit top, vermoed ik. Quote
SB-01 4.380 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Uiterlijk (te) weinig verschil met een ST-line vind ik persoonlijk. Bij de Mk2 zag je goed wanneer het om een ST ging en bij een RS viel het absurd hard op. Bij de Mk3 was dat al een stuk minder en nu nog eens minder. Quote
ir_fuel 58.442 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Is toch bij elk merk zo? M140i vs 120D met M pack. Audi S Line vs S4, of een A45 AMG vs een C160 met AMG pack. Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 Is inderdaad redelijk subtiel, maar dat maakt ook dat hij er niet te margi uitziet. (à la Civic Type R bv.) Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 Nog wat foto's: https://www.pistonheads.com/news/ph-eurocars/2019-ford-focus-st-gets-280hp-and-elsd/39640?fbclid=IwAR2Sa2bXCvI8Tpwd2_Aj-j7OatJWCjAs4p8-2Lr7zngWUOVD3z7cCsh82Xo 2 Quote
Mazdastruction 4.276 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Ik dacht dat het een topic in 'Mijn Auto' was. 2 1 1 Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 27 minuten geleden, Mazdastruction zei: Ik dacht dat het een topic in 'Mijn Auto' was. Ben skeer maat! Quote
Ambi 1.769 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Niet slecht maar een Megane RS doet me meer eigenlijk. Benieuwd hoe die verhouden ten opzichte van elkander qua rijkwaliteiten. Quote
Krikkie 9.879 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Van zijn/haar/X zijaanzicht bekeken zeer knap, zouden de problemen met de 2.3 van de baan zijn? Quote
ir_fuel 58.442 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 25 minutes ago, Krikkie said: Van zijn/haar/X zijaanzicht bekeken zeer knap, zouden de problemen met de 2.3 van de baan zijn? Die zijn al lang van de baan. Was blijkbaar een montagefout, maar eer ze dat gevonden hadden ... Quote
Denniske 7.651 Geplaatst: 18 februari 2019 Auteur Geplaatst: 18 februari 2019 26 minuten geleden, Ambi zei: Niet slecht maar een Megane RS doet me meer eigenlijk. Benieuwd hoe die verhouden ten opzichte van elkander qua rijkwaliteiten. Nieuwe Mégane R.S. zou niet zo geweldig zijn, is ook heel duur... Quote
Tiep 3.403 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Mooie ket0l, njam, approved! Quote
Vanni 1.628 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Ik ben benieuwd naar de break versie. Quote
Jochen 6.091 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Ford is goed bezig. De Focus is eindelijk een volwassen hatchback geworden ipv een noodzakelijk kwaad. Het interieur is ook een grote sprong vooruit. Dat hij goed zal rijden kunnen we ondertussen wel vanuit gaan zeker? Quote
gl3nn 9.425 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Lijkt in profiel op een oude Mazda 3 Hatchback, zelf de velgen doen me eraan denken 4 Quote
Timo 16.104 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 6 minutes ago, gl3nn said: Lijkt in profiel op een oude Mazda 3 Hatchback, zelf de velgen doen me eraan denken dat front (en die grille) oogt heel Aziatisch 1 Quote
Timo 16.104 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 alle kgon het mor zegge, tis precies nen aston martin Quote
Speedhunter 4.891 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Kan moeilijk wennen aan de nieuwe looks. Maar mooie wagen. Quote
jvc 543 Geplaatst: 18 februari 2019 Geplaatst: 18 februari 2019 Enigste wagen waarvan de nieuwe motor een grotere inhoud heeft dan de vorige? Benieuwd naar de reviews. Quote
Ambi 1.769 Geplaatst: 19 februari 2019 Geplaatst: 19 februari 2019 14 uren geleden, Denniske zei: Nieuwe Mégane R.S. zou niet zo geweldig zijn, is ook heel duur... Onlangs eens naar gekeken en zijn inderdaad wel prijzig maar vooral het aanbod was erg klein dus verkoopt precies niet goed. Op papier lijkt dat althans wel leuk materiaal die versie met sper en handbak, en ben echt fan van de looks. Quote
