Alexanderr 34.309 Geplaatst: 20 januari 2019 Delen Geplaatst: 20 januari 2019 Op 17/1/2019 om 13:12, ICM zei: Geluid buiten is niet denderend zegt die kerel. Zelfs met sportuitlaat. ? True; is een pak stiller dan 991-2 met sportuitlaat. Ik denk niet dat ik het zou speccen. 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
flupke73 9.455 Geplaatst: 20 januari 2019 Delen Geplaatst: 20 januari 2019 van Meneer 000: ^ Hello everyone!Just done with a day in the 992...road drive on (fortunately) GREAT mountain roads with a variety of surface conditions > wet handling course > full track. You always want more seat time, but this was pretty good as media launches go, with 1.5-2.0~ hours in the left seat plus an equal amount of time in the right seat. Other caveats: I'm gonna straight download here, rather than edit and re-edit. So consider these trip notes...first impressions that I may want to return to after some consideration.As far as the driving is concerned, let's get the verdict out up front: It's fantastic.Road test: C2S with PDCC & PCCB (3~ hours in the mountains)When it comes to chassis/handling/ride, I feel the 991.2 set a high bar in this regard, with a keen, alert, agile chassis that felt great to wring out. The added weight of the 992, as well as the engineering department's stated goal of improving wet performance/safety, had me a bit worried. I was also concerned that we would get too-smooth roads (or simply lame roads), but this wasn't the case.You do notice the added 50~ kilograms (this will vary depending on model and market) as well as the added width of the car over a 991.2 Carrera/S/T—but not in a major way while driving. In terms of driving, I'd say the added weight/width on a backroad are a 2~% disadvantage for +10-20% gains elsewhere (more to come on that). The weight gain stems mainly from the 8-speed PDK transaxle, with its new case, four main shafts, and large chamber to accomodate future hybrid gear. Additional weight stems outward from there, said one engineer, as the transmission is physically larger and requires a larger void in the body structure. It's pretty clear they worked hard to offset those gains.As for those gains? EPAS is, as expected, getting better with each generation since the 991.1. This system is, imo, very good—with response and precision that represents another step up from the 991.2 and now begs no comparison with a 996/986 or 997/987 rack. Porsche says the rack is 11% more direct than the 991.2's, and you can feel the difference. In the Normal mode at parking speeds, you're worried you are driving a Panamera. In Sport or Sport Plus at speed, those fears are forgotten. As for steering feel? I had the information I needed to go very quickly, early on—sooner than I would have expected after sitting down in an unfamiliar car on a challenging, unfamiliar road. One that not only had a lot of bumps and lumps (think northern CA backroads) but also occasional moisture and a "grease factor" even in the dry. Roll couple—the way the front and rear axles (German for suspension) work together—is also excellent, adding confidence as it doesn't feel like either end of the car is out of step with the other...adding confidence. Both ends offer a lot of grip, with the added track width helping up front and the same + the taller rear wheel/tire setup in the rear doing the same. The classic 911 slow-in, fast-out remains—but I'm not sure it's ever been more competent. The 997.2 GTS's PASM dampers were the first variable dampers to achieve damping perfection in my book, and the dampers in the 991.2 were similarly excellent, but the latest system—now able to alter their valving continuously rather than only at the top or bottom of the piston stroke—is a subtle revelation. Subtle, in that you don't even think about the damping. The car just flows over the road, but the body control is iron-fisted. Braking in our test car was also excellent...no surprise with PCCB, but the stiffer brake pedal is a nice upgrade and offers a substantive if similarly subtle improvement over the PCCB system offered in the 991.2. Brake dive is a non issue; same goes for squat under acceleration. (Note: I only tried the standard brakes on track, where they were excellent but eventually gave me less than 100% confidence...felt like they were feeling the heat despite no fade; I heard zero complaints about the standard brakes from others on the road driving portion of the day).Engine and transmission: I was worried that the 992's engine, in going up to 991.2 GTS power levels, would lose some of the 370-hp 3.0's N/A-ish-ness—moving more toward a turbocharged nature as the 420-hp and 450-hp 3.0s do as you move up the 991.2 range. The various charts only reinforced that fear, but in use on tight back roads, the new Carrera S engine feels a lot like the outgoing 370-hp engine in terms of character with the speed of the 991.2 GTS. The pace is nothing short of stunning for a Carrera-line car, or any car for that matter (as it is in the outgoing GTS). Porsche has also improved the engine noise, clearly benefitting from lessons learned after the first go with the 3.0, and there's enough noise for me where the 991.2 occasionally leaves me wanting more. The eight-speed PDK had my co-driver and I (both of us are diehard MT guys) shouting out loud about its shift speeds as well as intuition—but both of us ultimately preferred Manual modeCriticisms: Some wind noise on the freeway from the new door mirrors—a hiss heard from both seats, and one that could be a matter of these being pre-production or early production-spec cars or something we'll see in customer cars. It's very minor (you won't hear it if the radio is on, and it wasn't long before we didn't think about it anymore even with the radio off). My fingers slipped off the exterior door handle twice when it mattered (driver changes); not a fan of the new setup. I miss a simple button to select PASM damper settings, which are now accessed through a couple of screens if you want to cook up your own setup. New PCM, like the 991.2 system, offers good hardware but not as sure about the UI's intuitiveness; need to spend more time with this. You can't see the outer gauges on the new five-dial dash cluster; this was a decision made in order to increase the size of the "gauges" to either side of the tach. There are some surfaces in the interior I don't love, chiefly the piano black pieces to either side of the shifter—and one begins to wonder why the plastic trim to either side of the dash screen isn't piano black to better integrate with the screen (turns out the piece that angles into the tach was causing glare when it was piano black). Center vents in the dash aren't as optimally placed in their new location (a compromise to get the screen up).Surprises: The nubbin is actually form following function: Early in the design phase, a decision was taken to do something different here, and the engineers noted that a tall selector (as in the past) means the driver will feed a lot of torque into that lever; a smaller lever means less torque, and less needed in the console. It also encourages the driver to keep two hands on the wheel; my take? I didn't use the tunnel selector very often in 997/991 or 987/981/718 cars with PDK, so this is not a big loss for me. I don't love the look, but find the reasoning sound. What I would like is a more positive pair of paddles; would be cool if they offered the very mechanical paddles from the GT4 Clubsport as an option in all 992s. I was NOT a fan of PDCC in the 991.1, as I felt it robbed too much in terms of feedback for what it gained in performance. I am not sure I have had the seat time in the right 991.2s to comment on PDCC in that generation, but PDCC is now DIALED in the 992. Not sure I would order it, but I see little if any drawback. The dash top vent directional controllers stood out in Spain where I missed them before. These are related to the dash's center vent placement, a way to add a bit more control over air circulation in light of the loss of the high-mounted center vents. The steering wheel looks better than the already good 991.2 wheel—in every aspect except the rotary dial for Drive Mode, which does look a but cheap but, interestingly, was selected after many other finishes—including the shinier, more expensive-looking material on the various center switches—were deemed distracting. My take? The white lettering is the problem. As for why it lost the LEDs seen in the last generation: An additional LED seemed superfluous given the way the "gauge" to the right of the tach indicates the drive mode. The door pockets have "hidden" water bottle holders that will hold a 1.5-liter bottle upright just head of the grab handles.All up, from the road portion: In dynamic terms, the 992 feels more familiar than I thought it might be given the looks, marketing, and messaging. To me, it feels a lot like a 991.35—a welcome situation after how good the 991.2 Carrera is.There's a lot more to cover in terms of Wet Mode, chasing a 991.2 GT3 RS around a track I learned in a 918 Spyder a few years ago, and other observations, but I need to head off to do another interview for 000 coverage (would be good to get something of value for the book, too!). But, for now, consider this first notes, tapped out about as quickly as I can. 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Naish 8.009 Geplaatst: 20 januari 2019 Delen Geplaatst: 20 januari 2019 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
dane 1.816 Geplaatst: 21 januari 2019 Delen Geplaatst: 21 januari 2019 2 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Daggie 479 Geplaatst: 22 januari 2019 Delen Geplaatst: 22 januari 2019 1 2 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Daggie 479 Geplaatst: 22 januari 2019 Delen Geplaatst: 22 januari 2019 Deze heeft effectief nieuwe / nuttige info: 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Jokke_vlo 14.826 Geplaatst: 22 januari 2019 Delen Geplaatst: 22 januari 2019 Net eens kunnen bekijken van binnen en buiten en eigenlijk wat omgekeerd gevoel tov de foto’s. Die scherpere front met die uitgesproken panelen begonnen mijn aandacht te trekken en vond ik een tikje minder. Geef me maar het “smoothere” van de 991 atm. De kont, echter : Amaai die vond ik heel knap met de lichtpartij die mooi ingepast was in de brede heupen. Echt knap ! Je moet ze toch in het echt zien want op foto lijkt dat minder te “pakken”.Interieur is vernieuwd maar gaf me tweeledig gevoel. Ik mis het 911 gevoel toch net iets te veel, terwijl het dan ook weer geen panamera sfeer kan scheppen. Nog meer GT en minder uitgesproken sport zou ik zeggen waarbij ik een wat noch vlees noch vis gevoel had. Maar goed het is misschien ook nog allemaal even wennen...... mogelijk is het dat Dat blauw van op het salon is wel echt wauw ! 3 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Audi S8 1.651 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 3 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Audi S8 1.651 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
flupke73 9.455 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 8 uren geleden, Jokke_vlo zei: Net eens kunnen bekijken van binnen en buiten en eigenlijk wat omgekeerd gevoel tov de foto’s. Die scherpere front met die uitgesproken panelen begonnen mijn aandacht te trekken en vond ik een tikje minder. Geef me maar het “smoothere” van de 991 atm. op te lossen met 'bumper sportpakket', zou'k direct speccen Quote Link naar reactie Delen op andere sites Meer opties om te delen...
PJH 17.548 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Die gespoten splitter is dan weer mottig. Quote Link naar reactie Delen op andere sites Meer opties om te delen...
ir_fuel 52.282 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 52 minutes ago, flupke73 said: op te lossen met 'bumper sportpakket', zou'k direct speccen Verandert niks aan de lijn van de kofferklep tov de voorbumper. Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Naish 8.009 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Ik vind de voorkant net beter dan de 991... Als ik een gebogen moterkap wil, dan kijk ik wel naar de 356 En die zwarte 'happer' over de hele breedte vind ik net een verbetering, voor mij een reden om de sportdesign voorbumper zeker niet te pakken en wat PJH zegt van de meegespoten frontlip is ook waar. Interieur vind ik een heuze verbetering en de achterkant al altijd wauw gevonden, maar ja die van de 991 mag er ook zijn. Content dat ik hem gisteren eens op mijn gemak heb kunnen bekijken 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Davy_ 1.514 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Hij is knap, alleen die standaard bumpers... [emoji33][emoji1785] Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Naish 8.009 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 1 minuut geleden, Davy_ zei: Hij is knap, alleen die standaard bumpers... Voorbumper is smaak volgens mij en wat je graag ziet... Ik vind de standaard mooier dan de sportdesign, maar kan me voorstellen als je hem iets meer 991 look wil geven je de sportdesign beter gaat vinden. Maar die achterbumper sportdesign vind jij mooier??? Want die is echt wel en die reden dat die nummerplaat dan hoger zit is ook non issue want die zit daar ook maar in gescheten... Quote Link naar reactie Delen op andere sites Meer opties om te delen...
toere 14.719 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Content dat ik hem gisteren eens op mijn gemak heb kunnen bekijken [emoji3] Aaa heb je hem al?Proficiat he[emoji16] Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Davy_ 1.514 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Voorbumper is smaak volgens mij en wat je graag ziet... Ik vind de standaard mooier dan de sportdesign, maar kan me voorstellen als je hem iets meer 991 look wil geven je de sportdesign beter gaat vinden. Maar die achterbumper sportdesign vind jij mooier??? Want die is echt wel en die reden dat die nummerplaat dan hoger zit is ook non issue want die zit daar ook maar in gescheten...Voorbumper wel, achterbumper is het ook niet. Maar het standaard exemplaar is ook lelijk. Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Jokke_vlo 14.826 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Zoals altijd bij een nieuwe 911 is het even wennen en vinden we hem daarna, bijna, allemaal weer heel geslaagd.That’s how it works 5 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Naish 8.009 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Succes in het weerstaan @Jokke_vlo 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
tuscani 10.077 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 heeft onze naish een nieuw kapsel? Quote Link naar reactie Delen op andere sites Meer opties om te delen...
Naish 8.009 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 1 minuut geleden, tuscani zei: heeft onze naish een nieuw kapsel? Welkom in 2016 of zo Quote Link naar reactie Delen op andere sites Meer opties om te delen...
tuscani 10.077 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 2 minuten geleden, Naish zei: Welkom in 2016 of zo ah, dan is het al lang geleden dat we gaan karten zijn. 1 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
ir_fuel 52.282 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 5 hours ago, tuscani said: heeft onze naish een nieuw kapsel? Dit? Quote Link naar reactie Delen op andere sites Meer opties om te delen...
wabe 1.018 Geplaatst: 23 januari 2019 Delen Geplaatst: 23 januari 2019 Voor mij is het zeker... dit wordt de opvolger van de 550... 3 Quote Link naar reactie Delen op andere sites Meer opties om te delen...
